[GRASS-dev] Re: [GRASS-user] GRASS6.3 on Windows
Moritz Lennert
mlennert at club.worldonline.be
Sat Aug 25 18:04:54 EDT 2007
On Mon, August 20, 2007 22:38, Paul Kelly wrote:
> On Mon, 20 Aug 2007, Moritz Lennert wrote:
>> On Wed, August 8, 2007 20:49, Paul Kelly wrote:
>>> On Tue, 7 Aug 2007, Glynn Clements wrote:
>> Just checked out latest CVS and recompiled, and now I get the following
>> when I try to launch nviz from the menu (File -> 3D Rendering -> NVIZ):
>> When I display the spearfish DEM in a display window and then click on
>> the
>> nviz button of that window, nothing happens. No error messages, nothing
>> except for a brief appearance of r.info.exe in the Windows task manager.
> Hello Moritz,
> Works for me starting it both those ways, and also from command-line. I
> even tried make distclean and compiling from scratch in case there was
> something I'd manually fixed that kept it working on my system.
You are still using the May version of your library binaries ? Which
version of tcl/tk ?
> So I don't
> know what could be up with yours.
Just recompiled after distclean. I don't get the error message anymore
(don't know if this has anything to do with Michael's "cathing" efforts).
Now when I try to access nviz vie the File menu, it opens an empty wish
window entitled 'dialog0' and nothing else happens. When I try to launch
from the map diplay window, nothing happens at all.
>From the command line it runs perfectly, however.
> Maybe you have an old nviz.exe lying
> around in your PATH somewhere that is getting picked up when the GUI runs
> "nviz", instead of Glynn's new nviz.bat?
No can't find any other versions.
Am a bit clueless as to what might cause this problem...
Moritz
