[GRASS-dev] Re: [GRASS-user] GRASS6.3 on Windows
Moritz Lennert mlennert at club.worldonline.be
Sat Aug 25 18:23:23 EDT 2007
On Sun, August 26, 2007 00:04, Moritz Lennert wrote:
> On Mon, August 20, 2007 22:38, Paul Kelly wrote:
>> On Mon, 20 Aug 2007, Moritz Lennert wrote:
>>> On Wed, August 8, 2007 20:49, Paul Kelly wrote:
>>>> On Tue, 7 Aug 2007, Glynn Clements wrote:
>>> Just checked out latest CVS and recompiled, and now I get the following
>>> when I try to launch nviz from the menu (File -> 3D Rendering -> NVIZ):
>>> When I display the spearfish DEM in a display window and then click on
>>> the
>>> nviz button of that window, nothing happens. No error messages, nothing
>>> except for a brief appearance of r.info.exe in the Windows task
>>> manager.
> Just recompiled after distclean. I don't get the error message anymore
> (don't know if this has anything to do with Michael's "cathing" efforts).
> Now when I try to access nviz vie the File menu, it opens an empty wish
> window entitled  'dialog0' and nothing else happens. When I try to launch
> from the map diplay window, nothing happens at all.
>>From the command line it runs perfectly, however.
>> Maybe you have an old nviz.exe lying
>> around in your PATH somewhere that is getting picked up when the GUI
>> runs
>> "nviz", instead of Glynn's new nviz.bat?
> No can't find any other versions.
> Am a bit clueless as to what might cause this problem...
Maybe if someone could try my 20070825 binaries from
http://moritz.homelinux.org/grass/wingrass/ to see if the same problem
appears ?
Moritz
