[GRASS-dev] Re: [GRASS-user] GRASS6.3 on Windows
Moritz Lennert mlennert at club.worldonline.be
Sun Aug 26 15:24:58 EDT 2007
On Sun, August 26, 2007 01:02, Michael Barton wrote:
> Moritz,
> Update /gui/tcltk/gis.m/runandoutput.tcl from the cvs and see what
> happens.
Still the same problem.
> Also, are you doing nviz from the menu (opens nviz dialog) or nviz from
> the
> map display with a active raster map (launches nviz with the raster)?
Both: when calling it from the menus, I just get the dialog0 window. When
I call it from the map display, I get no reaction whatsoever.
I'll install my binaries on a different windows machine tomorrow to see
what happens.
Moritz
> Michael
> On 8/25/07 3:04 PM, "Moritz Lennert" <mlennert at club.worldonline.be> wrote:
>> On Mon, August 20, 2007 22:38, Paul Kelly wrote:
>>> On Mon, 20 Aug 2007, Moritz Lennert wrote:
>>>> On Wed, August 8, 2007 20:49, Paul Kelly wrote:
>>>>> On Tue, 7 Aug 2007, Glynn Clements wrote:
>>>> Just checked out latest CVS and recompiled, and now I get the
>>>> following
>>>> when I try to launch nviz from the menu (File -> 3D Rendering ->
>>>> NVIZ):
>>>> When I display the spearfish DEM in a display window and then click on
>>>> the
>>>> nviz button of that window, nothing happens. No error messages,
>>>> nothing
>>>> except for a brief appearance of r.info.exe in the Windows task
>>>> manager.
>>> Hello Moritz,
>>> Works for me starting it both those ways, and also from command-line. I
>>> even tried make distclean and compiling from scratch in case there was
>>> something I'd manually fixed that kept it working on my system.
>> You are still using the May version of your library binaries ? Which
>> version of tcl/tk ?
>>> So I don't
>>> know what could be up with yours.
>> Just recompiled after distclean. I don't get the error message anymore
>> (don't know if this has anything to do with Michael's "cathing"
>> efforts).
>> Now when I try to access nviz vie the File menu, it opens an empty wish
>> window entitled  'dialog0' and nothing else happens. When I try to
>> launch
>> from the map diplay window, nothing happens at all.
>> From the command line it runs perfectly, however.
>>> Maybe you have an old nviz.exe lying
>>> around in your PATH somewhere that is getting picked up when the GUI
>>> runs
>>> "nviz", instead of Glynn's new nviz.bat?
>> No can't find any other versions.
>> Am a bit clueless as to what might cause this problem...
>> Moritz
> __________________________________________
> Michael Barton, Professor of Anthropology
> Director of Graduate Studies
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
