[GRASS-dev] [grass-code I][471] nviz.bat should only be installed on Windows build
grass-dev at grass.itc.it grass-dev at grass.itc.it
Wed Aug 29 15:20:49 EDT 2007
code I item #471, was opened at 2007-08-29 14:20
Status: Open
Priority: 3
Submitted By: William Kyngesburye (kyngchaos)
Assigned to: Nobody (None)
Summary: nviz.bat should only be installed on Windows build
Issue type: module bug
Issue status: None
GRASS version: CVS HEAD
GRASS component: NVIZ
Operating system: MacOS X
Operating system version: 10.4
GRASS CVS checkout date, if applies (YYMMDD): 070808
Initial Comment:
After the 8/7 change to the nviz makefile (v1.14), nviz.bat is now installed on ALL systems.  It should only be installed on Windows (native only?).
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=471&group_id=21
