[GRASS-dev] gmath BLAS/LAPACK wrapper
Brad Douglas
rez at touchofmadness.com
Wed Aug 29 23:01:34 EDT 2007
On Sat, 2007-08-25 at 20:45 +0200, "Sören Gebbert" wrote:
> Hi Brad, Dear devs,
> i am currently working on a ATLAS - BLAS/LAPACK implementation
> within the gpde library.
> The idea is to provide full access to ATLAS BLAS level 1-3
> functions and have multi-threaded BLAS 1-3 functions implemented in GRASS
> as backup. I have almost finished the BLAS level 1 vector routines and
> working on
> level 2 the vector - matrix and level 3 matrix - matrix implementation.
It took me a little bit to get back on this. I needed to ensure that
ATLAS supports all of the LAPACK functions we need (it only supports a
subset).
We also missed each other (probably by minutes) several times on
IRC. :-)
> The grass BLAS level 1-3 implementation is of course not as fast as
> the ATLAS library.
> ATLAS is cache optimized and uses recursive functions.
> Additionally, ATLAS uses pthreads to provide multi threaded level 3 functions.
Sounds good to me. I'll have to look into replacing autotools
BLAS/LAPACK detection with ATLAS. It shouldn't be terribly difficult
unless we want to support all derivatives of CBLAS/CLAPACK.
I could use a little direction there as to which way to go. Glynn?
Markus?
> But for each specialised ATLAS function, a more general grass functions
> will exists. Eg: there are level 3 functions for quadratic, symmetric and hermitian
> matrices in BLAS, grass will provide only one matrix-matrix function.
> If the user compiles grass without ATLAS support, all the modules
> which are using
> BLAS functions will still work ... but not that fast. ;)
That works for me. This prevents the current caveat of "install
BLAS/LAPACK or these modules won't compile".
Do all of the lower level functions in lib/gmath, then lib/gpde calls
the gmath function, which automatically determins which version to run
(actually, it'll be determined at compile time).
> I try to keep the interface as simple as i can. The vectors are 1d
> float or double arrays
> and matrices are 1d float or double arrays with additional row
> pointers (using the G_alloc_vector and
> G_alloc_matrix functions). I use the same low level implementation
> as the ATLAS interface. The user must take care of correct allocation
> and row, column counting.
> Additionally i will try to create a wrapper to the LAPACK solver
> provided in ATLAS.
> IMHO the gpde lu decomposition with row pivoting
> and the gpde bandwidth optimized cholesky solver are the backup routines
> for most of the LAPACK sover.
> The krylov space solver (cg and bicgstab) will use the ATLAS BLASS 1-2
> functions.
> So the gpde interface is much more low level than the gmath LAPACK/BLAS
> wrapper. And i think we can use the gpde routines instead of the native
> lapack routines in the gmath warpper. But the matrix functions will work
> in row major order.
If you have lower level functions, then those should be moved to
lib/gmath, IMO.
> The blas functions are named like the (IMHO horrible)
> netlib-blas naming convention, accept that i have put a N_ before the name.
> Eg:
> N_cblas_ddot, N_cblas_sdot ... .
I'd rather use G_math_ddot (), G_math_sdot ()...
I think it'll be simpler to determine the function operation at compile
time rather than run time.
73, de Brad KB8UYR/6 <rez touchofmadness com>
