[GRASS-dev] gmath BLAS/LAPACK wrapper
"Sören Gebbert" soerengebbert at gmx.de
Fri Aug 31 18:05:39 EDT 2007
-------- Original-Nachricht --------
> Datum: Thu, 30 Aug 2007 03:01:34 +0000
> Von: Brad Douglas <rez at touchofmadness.com>
> An: "Sören "Gebbert\\"" <soerengebbert at gmx.de>
> CC: grass-dev at grass.itc.it, Glynn Clements <glynn at gclements.plus.com>, Markus Neteler <neteler at itc.it>
> Betreff: Re: [GRASS-dev] gmath BLAS/LAPACK wrapper
> On Sat, 2007-08-25 at 20:45 +0200, "Sören Gebbert" wrote:
> > Hi Brad, Dear devs,
> > i am currently working on a ATLAS - BLAS/LAPACK implementation
> > within the gpde library.
> > The idea is to provide full access to ATLAS BLAS level 1-3
> > functions and have multi-threaded BLAS 1-3 functions implemented in
> GRASS
> > as backup. I have almost finished the BLAS level 1 vector routines and
> > working on
> > level 2 the vector - matrix and level 3 matrix - matrix implementation.
> It took me a little bit to get back on this.  I needed to ensure that
> ATLAS supports all of the LAPACK functions we need (it only supports a
> subset).
> We also missed each other (probably by minutes) several times on
> IRC. :-)
Ill keep on trying. :)
> > The grass BLAS level 1-3 implementation is of course not as fast as
> > the ATLAS library.
> > ATLAS is cache optimized and uses recursive functions.
> > Additionally, ATLAS uses pthreads to provide multi threaded level 3
> functions.
> Sounds good to me.  I'll have to look into replacing autotools
> BLAS/LAPACK detection with ATLAS.  It shouldn't be terribly difficult
> unless we want to support all derivatives of CBLAS/CLAPACK.
> I could use a little direction there as to which way to go.  Glynn?
> Markus?
> > But for each specialised ATLAS function, a more general grass functions
> > will exists. Eg: there are level 3 functions for quadratic, symmetric
> and hermitian
> > matrices in BLAS, grass will provide only one matrix-matrix function.
> > If the user compiles grass without ATLAS support, all the modules
> > which are using
> > BLAS functions will still work ... but not that fast. ;)
> That works for me.  This prevents the current caveat of "install
> BLAS/LAPACK or these modules won't compile".
> Do all of the lower level functions in lib/gmath, then lib/gpde calls
> the gmath function, which automatically determins which version to run
> (actually, it'll be determined at compile time).
Thats a good idea, i will place the lower level functions from the gpde library
into the gmath library. This will include the ATLAS wrapper, the grass blas level 1-3
implementation and all the linear equation solver i have implemented.
> > I try to keep the interface as simple as i can. The vectors are 1d
> > float or double arrays
> > and matrices are 1d float or double arrays with additional row
> > pointers (using the G_alloc_vector and
> > G_alloc_matrix functions). I use the same low level implementation
> > as the ATLAS interface. The user must take care of correct allocation
> > and row, column counting.
> > Additionally i will try to create a wrapper to the LAPACK solver
> > provided in ATLAS.
> > IMHO the gpde lu decomposition with row pivoting
> > and the gpde bandwidth optimized cholesky solver are the backup routines
> > for most of the LAPACK sover.
> > The krylov space solver (cg and bicgstab) will use the ATLAS BLASS 1-2
> > functions.
> > So the gpde interface is much more low level than the gmath LAPACK/BLAS
> > wrapper. And i think we can use the gpde routines instead of the native
> > lapack routines in the gmath warpper. But the matrix functions will work
> > in row major order.
> If you have lower level functions, then those should be moved to
> lib/gmath, IMO.
Agreed.
> > The blas functions are named like the (IMHO horrible)
> > netlib-blas naming convention, accept that i have put a N_ before the
> name.
> > Eg:
> > N_cblas_ddot, N_cblas_sdot ... .
> I'd rather use G_math_ddot (), G_math_sdot ()...
> I think it'll be simpler to determine the function operation at compile
> time rather than run time.
Ok, i will name the blas 1 - 3 ATLAS function as you suggested.
But how should i name the grass backup blas functions? Currently i dont use the
blas naming convention because its to cryptic.
Because the grass blas implementation is more general, i have named those
functions like: N_blas1_d_xdoty() or N_blas2_d_Ax_by() and so on.
So i will name it G_math_blas1_d_xdoty() ....
What parts of the LAPACK functions do we need in grass currently and
ion the future? Because ATLAS supports only a few of them, this is an important
question i think.
Best regards
soeren
> 73, de Brad KB8UYR/6 <rez touchofmadness com>
Ist Ihr Browser Vista-kompatibel? Jetzt die neuesten
Browser-Versionen downloaden: http://www.gmx.net/de/go/browser
