[GRASS-dev] proj file not found
Tim Michelsen
timmichelsen at gmx-topmail.de
Mon Dec 3 06:19:15 EST 2007
Hello,
I am using the Ubuntu packages from:
http://les-ejk.cz/ubuntu/
When I want to create a new location based on EPSG codes the program looks for
the epsg file in
/usr/local/share/proj/epsg
This file does not exist because it is in
/usr/share/proj/epsg
What do we need to do do correct this?
Another thing is that there should be a explication why the SAD69 datum ist
called sam69 in GRASS.
Kind regards,
Tim
