[GRASS-dev] proj file not found
Mon Dec 3 11:53:26 EST 2007
Tim Michelsen wrote:
> I am using the Ubuntu packages from:
> http://les-ejk.cz/ubuntu/
> When I want to create a new location based on EPSG codes the program looks for
> the epsg file in
> /usr/local/share/proj/epsg
> This file does not exist because it is in
> /usr/share/proj/epsg
> What do we need to do do correct this?
Setting the environment variable GRASS_PROJSHARE to
/usr/local/share/proj should work.
