[GRASS-dev] location invalid if PERMANENT contains no WIND file ?
Maris Nartiss
maris.gis at gmail.com
Fri Dec 7 06:44:20 EST 2007
Is this somewhere defined? I mean - where is the documentation about
valid location/mapset requirements?
Maris.
2007/12/7, Glynn Clements <glynn at gclements.plus.com>:
> Moritz Lennert wrote:
> > In gis_set.tcl there is a check for a valid location which reads:
> > # All good locations have valid PERMANENT mapset.
> > if {[file exists "$dir/PERMANENT/WIND"] != 0} {
> > set found 1
> > Shouldn't this check for DEFAULT_WIND instead of WIND ?
> I can see some sense in that. The only time that PERMANENT/WIND will
> actually be used is if PERMANENT is used as the current mapset, which
> may never happen. OTOH, PERMANENT/DEFAULT_WIND must exist in order to
> create new mapsets.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
