[GRASS-dev] location invalid if PERMANENT contains no WIND file ?
Patton, Eric epatton at nrcan.gc.ca
Fri Dec 7 07:30:44 EST 2007
There is some documentation about specifying paths and environmental variables here:
http://grass.itc.it/grass63/manuals/html63_user/grass6.html
and a little bit about the inheiritance of DEFAULT_WIND in PERMANENT to all other mapsets here:
http://grass.itc.it/grass63/manuals/html63_user/helptext.html
~ Eric.
-----Original Message-----
From: grass-dev-bounces at lists.osgeo.org on behalf of Maris Nartiss
Sent: Fri 12/7/2007 7:44 AM
To: Glynn Clements
Cc: grass-dev
Subject: Re: [GRASS-dev] location invalid if PERMANENT contains no WIND file ?
Is this somewhere defined? I mean - where is the documentation about
valid location/mapset requirements?
Maris.
2007/12/7, Glynn Clements <glynn at gclements.plus.com>:
> Moritz Lennert wrote:
> > In gis_set.tcl there is a check for a valid location which reads:
> > # All good locations have valid PERMANENT mapset.
> >     if {[file exists "$dir/PERMANENT/WIND"] != 0} {
> >        set found 1
> > Shouldn't this check for DEFAULT_WIND instead of WIND ?
> I can see some sense in that. The only time that PERMANENT/WIND will
> actually be used is if PERMANENT is used as the current mapset, which
> may never happen. OTOH, PERMANENT/DEFAULT_WIND must exist in order to
> create new mapsets.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
