[GRASS-dev] Re: error saving tifs from NVIZ in winGRASS
Benjamin Ducke
benjamin.ducke at ufg.uni-kiel.de
Thu Dec 20 03:38:14 EST 2007
Moritz Lennert wrote:
> So, unless someone decides to rewrite nviz to use gdal, I guess we will
> have to compile wingrass with tiff support. Or maybe we can use existing
> libtiff binaries from mingw or gnuwin32.
> Moritz
That's easy enough. Note, however, that you have to build and install
LibJPEG first.
In the text below, I assume that you have headers and libs in
C:\msys\1.0\include, C:\msys\1.0\lib. Adjust paths as necessary.
INSTRUCTIONS FOR BUILDING ON MINGW/MSYS:
LibJPEG 6b
The easiest way is to use the MinGWport file from
http://sourceforge.net/project/showfiles.php?group_id=2435. Download the
file jpeg-6b-mingwPORT.tar.bz2 from there and save it to
C:\msys\1.0\src. The package contains an install script mingwPORT.sh
that makes it easy to download, patch and install LibJPEG under MSYS.
cd /src
tar -xjf jpeg-6b-mingwPORT.tar.bz2
cd jpeg-6b/mingwPORT
sh mingwPORT.sh
This will start the install script. Answer the questions as follows from
this transcript (note: you can go with the defaults except for
``Installation directory''):
Download file? (Yes) y
Download file URI? (ftp://ftp.uu.net/graphics/jpeg)
Archive file type?
0) unknown
1) tar.gz
2) tgz
3) tar.bz2
4) tbz2
5) zip
Select a numeric value: (1)
Archive file? (jpegsrc.v6b.tar.gz)
Download to path? (/tmp)
Source path? (/usr/src/jpeg-6b) /usr/src/jpeg-6b
Installation directory? (/mingw) /usr
CFLAGS (-O3 -s -mms-bitfields -march=i686)
Now wait for the install script to download the source code, patch,
compile and install it.
LibTIFF 3.8.2
Download the file tiff-3.8.2-mingwPORT.tar.bz2 from there and save it to
C:\msys\1.0\src. The package contains a shell script that makes it easy
to download, patch and install LibTIFF under MSYS.
cd /src
tar -xjf tiff-3.8.2-mingwPORT.tar.bz2
cd tiff-3.8.2/mingwPORT
sh mingwPORT.sh
this transcript. Strangely enough, the default options will not work, so
make sure to specify the C and C++ flags as shown below:
Download file URI? (ftp://ftp.remotesensing.org/pub/libtiff)
Archive file type?
0) unknown
1) tar.gz
2) tgz
3) tar.bz2
4) tbz2
5) zip
Archive file? (tiff-3.8.2.tar.gz)
Source path? (/usr/src/tiff-3.8.2)
CFLAGS (-O3 -s -mms-bitfields -march=i686) -O3 -s -mms-bitfields
-march=i686 -I/usr/include -L/usr/lib -ljpeg
CXXFLAGS (-O3 -s -mms-bitfields -march=i686) -O3 -s -mms-bitfields
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
