[GRASS-dev] Re: error saving tifs from NVIZ in winGRASS
Moritz Lennert
mlennert at club.worldonline.be
Thu Dec 20 04:13:44 EST 2007
On 20/12/07 09:38, Benjamin Ducke wrote:
> Moritz Lennert wrote:
>> So, unless someone decides to rewrite nviz to use gdal, I guess we will
>> have to compile wingrass with tiff support. Or maybe we can use existing
>> libtiff binaries from mingw or gnuwin32.
>> Moritz
> That's easy enough. Note, however, that you have to build and install
> LibJPEG first.
> In the text below, I assume that you have headers and libs in
> C:\msys\1.0\include, C:\msys\1.0\lib. Adjust paths as necessary.
Thanks !
Moritz
