[GRASS-dev] Re: [GRASS-trac] #7: Location wizard: should predefine DB connection for new location
GRASS-trac trac at osgeo.org
Sun Dec 30 11:54:49 EST 2007
  Reporter:  neteler  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  major    |   Milestone:  6.3.0
 Component:  Python   |     Version:  unspecified
Resolution:           |    Keywords:
Comment (by cmbarton):
 Replying to [ticket:7 neteler]:
 > The Location wizard does not predefine the DB connection for new
 location which leads to problems with several modules (needs to generate
 MAPSET/VAR file). Probably we should predefine SQLite here.
 I agree. However, except for xy locations, all are created using g.proj.
 So this is an issue for g.proj. That is, the location wizard does not
 operate 'inside' a location where it could use GRASS commands to do this.
 Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/7#comment:1>
GRASS-trac <http://grass.osgeo.org>
Commonly referred to as GRASS, this is a Geographic Information System (GIS) used for geospatial data management and analysis, image processing, graphics/maps production, spatial modeling, and visualization. GRASS is currently used in academic and commercial settings around the world, as well as by many governmental agencies and environmental consulting companies.
