[GRASS-dev] Re: [GRASS-trac] #7: Location wizard: should predefine
DB connection for new location
GRASS-trac
trac at osgeo.org
Mon Dec 31 08:44:24 EST 2007
#7: Location wizard: should predefine DB connection for new location
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.3.0
Component: Python | Version: svn-trunk
Resolution: | Keywords:
Changes (by neteler):
* cc: pkelly, cmbarton (added)
* version: unspecified => svn-trunk
Comment:
Paul,
could you please take a look? It affects g.proj which should call
functionality from Vect_default_field_info() to define the VAR
file for the DBMI connection in a newly created location
(see lib/vector/Vlib/field.c). I guess that implementation in
g.proj takes 10 minutes max... :)
Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/7#comment:2>
GRASS-trac <http://grass.osgeo.org>
Commonly referred to as GRASS, this is a Geographic Information System (GIS) used for geospatial data management and analysis, image processing, graphics/maps production, spatial modeling, and visualization. GRASS is currently used in academic and commercial settings around the world, as well as by many governmental agencies and environmental consulting companies.
