[GRASS-dev] [bug #5462] (grass) GRASS should support exporting E00
Maciek Sieczka via RT grass-bugs at intevation.de
Fri Feb 2 10:56:20 EST 2007
guest wrote (Fri, Feb 2 2007 03:31:25):
> It is possible that GRASS will be support v.out.e00 in the next
> version.Infact, I am using both arc/info and grass, So, I demand GRASS
> version 6.0 supporting export e.00 format (V.out.e00), because I can
> exchange GIS data between agencies in Thailand that mostly use arc/info.
I suppose that the best way to go, and most likely to succeed, would be to ask
for (even better - fund) the support for writing E00 in GDAL/OGR library
http://www.gdal.org/ogr/, which GRASS uses for vector import/export. Then a
wide variety of FOSS GIS, including GRASS, could use this functionality.
Note that GDAL 1.4.0 already supports E00 for reading. See:
http://www.gdal.org/NEWS.html
Maciek
-------------------------------------------- Managed by Request Tracker
