[GRASS-dev] d.rgb and d.zoom
Fri Feb 2 22:11:56 EST 2007
Markus Neteler wrote:
> would it be possible to change something so that
> d.zoom also understands if only d.rgb was used
> in the monitor?
d.zoom/redraw.c should have an option to use d.redraw to redraw the
display. It's arguable that should be the *only* option (i.e. no rast=
or vector= options).
