[GRASS-dev] [bug #5471] (grass) d.vect too noisy
Request Tracker
grass-bugs at intevation.de
Sun Feb 4 17:44:35 EST 2007
this bug's URL: http://intevation.de/rt/webrt?serial_num=5471
Subject: d.vect too noisy
G63> d.erase
G63> d.rast elevation.dem
G63> d.vect bugsites icon=basic/diamond col=white fcol=red
WARNING: Line color and background color are the same!
or
G63> d.erase blue
If that warning needs to exist at all, it should check to see if the monitor
command list is empty or there are no raster maps displayed (eg d.what.rast)
before doing so.
Otherwise it is unneeded noise in the terminal whenever you use the color
white for something -- which may make a more important error message harder to
spot.
thanks,
Hamish
-------------------------------------------- Managed by Request Tracker
