[GRASS-dev] v.db.dropcol added
Markus Neteler
neteler at itc.it
Mon Feb 5 12:01:06 EST 2007
Hi John,
On Mon, Feb 05, 2007 at 11:48:24AM -0500, John Gillette wrote:
> Hi Markus,
> I looked at you script without actually running it. I have a few
> questions (which may or may not be good).
excellent observations!
> (1) You check for an error in the non-sqlite case. Shouldn't you also
> check in the sqlite case?
Sure. Fixed.
> (2) If there is an error, the script exits before erasing the TMP files.
> Shouldn't you erase these even if there is an error?
Yep. Also fixed (now with common cleanup() function).
> (3) I think you missed $TMP.coldesc. You want to erase that one too?
Right. Fixed.
> Thanks for all your hard work.
Thanks for your feedback! Updated in CVS.
Markus
> John
> > -----Original Message-----
> > From: grass-dev-bounces at grass.itc.it
> > [mailto:grass-dev-bounces at grass.itc.it] On Behalf Of Markus Neteler
> > Sent: Monday, February 05, 2007 8:27 AM
> > To: grass developers list
> > Subject: [GRASS-dev] v.db.dropcol added
> > Hi,
> > thanks to the new ALTER TABLE DROP COLUMN addition for the
> > DBF driver, I have submitted a new "v.db.dropcol" script to
> > CVS. It includes extra code for SQLite DBs since SQLite
> > doesn't originally support column dropping. Using
> > "v.db.dropcol", however, you can drop columns in any GRASS
> > table connected to a vector map. Testing obviously welcome.
> > cheers
> > Markus
> > grass-dev mailing list
> > grass-dev at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass-dev
