[GRASS-dev] [bug #5478] (grass) v.in.gpsbabel broken for attributes
Request Tracker
grass-bugs at intevation.de
Mon Feb 5 18:15:37 EST 2007
this bug's URL: http://intevation.de/rt/webrt?serial_num=5478
Subject: v.in.gpsbabel broken for attributes
Platform: GNU/Linux/x86
grass obtained from: CVS
grass binary for platform: Compiled from Sources
I tried v.in.gpsbabel today, but:
v.in.gpsbabel -t in=/dev/ttyUSB0 format=garmin out=mytracks
Downloading Tracks from GPS
'style=/home/neteler/soft/63grass_cvsexp/dist.i686-pc-linux-gnu/etc/grass_write_ascii.style' is an unknown option to gpx.
Attempting waypoint projection transform with cs2cs
Importing with v.in.ascii
WARNING: The vector 'mytracks' already exists and will be overwritten.
Building topology ...
104 primitives registered
Building areas: 100%
0 areas built
0 isles built
Attaching islands:
Attaching centroids: 100%
Topology was built.
Number of nodes : 198
Number of primitives: 104
Number of points : 0
Number of lines : 104
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
v.in.ascii complete.
v.in.gpsbabel: line vector "mytracks at neteler" successfully created
Creating new table..
Populating table with attributes..
DBMI-DBF driver error:
SQL parser error in statement:
INSERT INTO mytracks VALUES (1, ' ', , , ' ', , )
Error in db_execute_immediate()
ERROR: Error while executing: "INSERT INTO mytracks VALUES (1, ' ', , , '
Connecting attribute table to vector file..
WARNING: The table <mytracks> is now part of vector map <mytracks> and may
be deleted or overwritten by GRASS modules
WARNING: Select privileges were granted on the table
Done.
Apparently the style file is no longer accepted in this form when
downloading tracks/routes from GPS.
http://www.gpsbabel.org/htmldoc-1.3.2/fmt_gpx.html
http://www.gpsbabel.org/htmldoc-development/fmt_custom.html
Markus
-------------------------------------------- Managed by Request Tracker
