[GRASS-dev] [bug #5481] (grass) BFD 2.16.91.0.7 20060317 internal
error, aborting at elfcode.h
Glynn Clements
glynn at gclements.plus.com
Tue Feb 6 16:30:12 EST 2007
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=5481
> Subject: BFD 2.16.91.0.7 20060317 internal error, aborting at elfcode.h
> Platform: GNU/Linux/x86_64
> grass obtained from: Trento Italy site
> grass binary for platform: Compiled from Sources
> GRASS Version: grass 6.2.1 (2006)
> I've got this message in a make >& make.out
> gcc -shared -o /usr/local/src/grass-6.2.1/dist./lib/libgrass_gproj.6.2.1.so -L/usr/local/src/grass-6.2.1/dist./lib -Wl,--export-dynamic -Wl,-rpath-link,/usr/local/src/grass-6.2.1/dist./lib OBJ./get_proj.o OBJ./do_proj.o OBJ./convert.o OBJ./datum.o OBJ./ellipse.o -lgrass_gis -lgrass_datetime -lz -lproj -L/usr/lib64 -lgdal && if [ -z "" ] ; then ln -f -s libgrass_gproj.6.2.1.so /usr/local/src/grass-6.2.1/dist./lib/libgrass_gproj.so; fi
> /usr/bin/ld: BFD 2.16.91.0.7 20060317 internal error, aborting at elfcode.h line 190 in bfd_elf64_swap_symbol_in
> /usr/bin/ld: Please report this bug.
This is an error in "ld" (the linker, from the "binutils" package). It
should be reported to the binutils maintainers, or to the maintainers
of your OS distribution. There isn't anything which the GRASS
developers can do about it.
