[GRASS-dev] [bug #5483] (grass) g.mremove through gis manager
GUI seems not to work well
Michael Barton
michael.barton at asu.edu
Wed Feb 7 10:14:54 EST 2007
These kinds of interactive questions and often extraneous warnings seem to
be popping a lot recently. It's almost like they were built into the code
but not being triggered and some recent change has triggered them.
An especially annoying one warns me that map I am using is indeed the same
map that I am using in the mapset where I'm working.
The problem reported here hangs the code in the auto-generated gui dialogs
for modules, not the general GIS Manager gui. I haven't ventured into that
code much; Cedric Shock and Glynn Clements know it best. I suspect that
you're right and the -f flag needs to be added as a default when the module
is started without arguments (i.e., launches the module GUI).
The odd thing is that this was not happening until recently. So the larger
question is why are we now getting a lot of verbose warnings and interaction
request that didn't happen before?
Michael
On 2/7/07 3:07 AM, "Markus Neteler" <neteler at itc.it> wrote:
> Request Tracker wrote on 02/07/2007 10:59 AM:
>> this bug's URL: http://intevation.de/rt/webrt?serial_num=5483
>> Subject: g.mremove through gis manager GUI seems not to work well
>> Platform: GNU/Linux/ppc
>> grass obtained from: Mirror of Trento site
>> grass binary for platform: Compiled from Sources
>> GRASS Version: GRASS6.2/6.3
>> Aldo Clerici.
>> The command File > Manage maps and volumes > Remove maps using expressions
>> and wildcards require an acknowledgment in the form:
>> Collecting map names for current mapset <esercizi>....
>> g.remove rast=geology.new,slope.new
>> Did you mean this (y/n)?
>> But it seems not to accept any kind of input (y,yes,n,no). It seems to wait
>> for something else.
> Aldo,
> up to now interactive input in tcl based dialogs is not possible.
> Using the -f flag (force removal) you can delete also in gis.m.
> Probably we need to enforce -f somehow in gis.m - how to do that?
> Markus
>> Same behaviour in grass6.2 and 6.3.
>> The same command g.mremove in command line mode works well.
>> -------------------------------------------- Managed by Request Tracker
>> grass-dev mailing list
>> grass-dev at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grass-dev
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
