[GRASS-dev] [grass-code issues][279] Define location with EPSG codes hangs grass
grass-codeissues at wald.intevation.org grass-codeissues at wald.intevation.org
Sat Feb 10 06:21:07 EST 2007
code issues item #279, was opened at 2007-02-10 12:21
Status: Open
Priority: 3
Submitted By: Carlos Dávila (carluti)
Assigned to: Nobody (None)
Summary: Define location with EPSG codes hangs grass
Issue type: module bug
Issue status: None
GRASS version: CVS HEAD
GRASS component: None
Operating system: Linux
Operating system version: debian testing 2.6.18-3-486
GRASS CVS checkout date, if applies (YYMMDD): 070210
Initial Comment:
When I try to define a new location from startup window, using the option EPSG codes I give the code number (23030) and click on Define location button and grass hangs and I have to close and restart it. I've tried in two different machines with the same linux and grass installation (cvs snapshot from 07-02-04 and 07-02-10) and problem is the same
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=279&group_id=21
