[GRASS-dev] g.proj to create a new location
Paul Kelly
paul-grass at stjohnspoint.co.uk
Sat Feb 10 10:10:59 EST 2007
Hello Hamish
On Thu, 8 Feb 2007, Hamish wrote:
> I have now added new epsg= and datumtrans= options to g.proj in CVS.
> The epsg= option to create new location by EPSG code is fully
> functional: (it just plugs the code into a PROJ4 format string)
> G63> g.proj -c loc=newlocNZTM epsg=2193
> Location newlocNZTM created!
> If it needs more info WRT datum transform options, it currently goes
> interactive as the datumtrans= option to list or select datum transform
> parms is not yet functional. Paul, can you try and connect this to
> get_datum_transform_by_name() and GPJ_ask_datum_params(), or wherever
> the number needs to get to? Mucho gracias.
I have this working now in my local copy, but just realised a slight flaw
with it. Because we are assuming a default of datumtrans=1, there is no
way to assume if the user specifically asked for the 1st set of datum
transformation parameters, or they are just using the default. Up to now,
if the user didn't specifically specify datum transformation parameters,
they were not written into the PROJ_INFO, only the datum name. When
necessary then (e.g. using one of the re-projection modules), the current
default parameters for that datum would be read from the datum.table file
and used. So if the default changed (e.g. we discovered it was wrong and
updated it) the user wouldn't need to edit their location to take
advantage of the update. But if the parameters are written into the
PROJ_INFO, then whatever default was in force at the time becomes set in
stone.
The logic in a few parts of the GRASS gproj library also uses the
presence/absence of specific transformation parameters in the PROJ_INFO as
an indicator of how likely any parameters present are to be
correct/appropriate for the location.
E.g. when writing an output WKT file, GRASS always puts the datum name
in, but only adds TOWGS84 parameters if they were specifically specified
in the PROJ_INFO. Again, the logic is that the parameters had been
specifically specified so there was a good chance they were correct and
there was no harm promulgating them on. But if the user had just accepted
the default parameters, then we're not so sure if they're appropriate for
the specific area of the data, so just put the datum name in and whoever
receives the export data can use their own initiative in choosing
appropriate parameters.
With this new functionality however, we are always assuming the user
specified datumtrans=xxx, so the parameters are always written in.
I'm not sure what to do about this, whether it's nothing to worry about or
not.
Also, I was wondering what format would be appropriate for the
GUI-parsable list of datum transformation parameters. In the copy I have
I'm just printing to stdout the list that you got by typing list at the
old interactive prompt. Are there any existing examples of something
similar I wonder.
Paul
