[GRASS-dev] display/drivers/HTMLMAP status
Tue Feb 13 07:21:06 EST 2007
Markus Neteler wrote:
> I have seen that we have
> in 6.3-CVS but it miserably fails to compile.
> This is the last trace:
> http://grass.itc.it/pipermail/grassuser/2007-January/037891.html
> I think that it is a nice driver but I cannot estimate
> how painful an update would be.
As I said before, unless someone fixes d.vect to use the driver's
polygon-filling operations (for map areas, not just label boxes),
there isn't any point in having the HTMLMAP driver.
