[GRASS-dev] Re: gis.m, thematic layer: You must open a display monitor
Moritz Lennert mlennert at club.worldonline.be
Tue Feb 13 09:58:14 EST 2007
On 13/02/07 15:29, Michael Barton wrote:
> I have no idea. Perhaps I'm imagining things, but I swear that I'm seeing a
> LOT more of these messages recently--with their deleterious effects on
> scripting. Hamish says they've been there all along. I'm suspecting that the
> code for the message has existed, but they did not get parsed for some
> reason. But that is just speculation.
Well in this case, there is a change by Daniel dated Jan. 28 which might
be linked:
- Added quotes in occurences of 'if [ -z "$var" ]'
But reverting back to no quotes gives the same error message.
Looking at the logic, I don't actually understand how this worked
before. As I said, IIUC the x-mon test seems to be done whether you are
using GIS Manager or not. But under GIS Manager there should be no x-mon...
Conditonalising the check as follows:
if [ "$GIS_FLAG_S"  -eq 0 ] ; then
   if [ -z "$currmon" ] ; then
         echo ""
         echo "*** You must open a display monitor ***"
         echo ""
         cleanup
         exit 2
   fi
fi
makes the error message go away, but I get a new one:
Usage:  /usr/lib/grass/etc/mon.select monitor_name
This time, however, the map and legend are displayed correctly (without
the "fix" only the legend is displayed). I can get this second error
message to go away by commenting line 862:
#               d.mon select=$currmon
This comes from the fact that $currmon is empty in GIS Manager. Again, I
don't understand why we have to deal with d.mon here if we are in the
GIS Manager...and why this did not cause any problems before.
Moritz
> Michael
> On 2/13/07 6:19 AM, "Moritz Lennert" <mlennert at club.worldonline.be> wrote:
>> Michael,
>> I am seeing a new error for d.vect.thematic. Trying to display a
>> thematic layer fails with the message: *** You must open a display
>> monitor ***
>> I can reproduce this with any spearfish vector layer.
>> The problem seems to be in lines 336-345 where it checks for the
>> existance of an x-monitor. It seems to do this unconditionally, so even
>> if you run it from the GIS Manager it still checks and fails if there is
>> not monitor.
>> I can't find anything recent in the commit logs that would explain this,
>> so before trying to go deeper into it, I wanted to know if you had an
>> idea why this is suddenly happening.
>> Moritz
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
