[GRASS-dev] Re: gis.m, thematic layer: You must open a display monitor
Daniel Calvelo dca.gis at gmail.com
Tue Feb 13 11:41:53 EST 2007
Hi Michael, Moritz.
I'll look at it when I get home. That's in about 10 hours.
Daniel.
BTW did you try d.vect.thematic for >20 categories? Legends now do
have their nice cut in the middle.
On 2/13/07, Moritz Lennert <mlennert at club.worldonline.be> wrote:
> On 13/02/07 16:06, Michael Barton wrote:
> > There should be a flag to send output to the gis manager. This flag should
> > cause this conditional to be skipped.
> The flag is $GIS_FLAG_S:
> On line 860ff you have this:
> # reset rendering for GUI use
>       if [ "$GIS_FLAG_S"  -eq 1 ] ; then
>         d.mon select=$currmon
> fi
> In my understanding, unless someone works in parallel with GIS Manager
> and x-mons, $currmon will be empty and this is where this error message
> comes from.
> Maybe it's just a problem of an unequal number of if and fi calls...
> But I don't have the time to go into the file in detail now...sorry.
> Moritz
> > Michael
> > On 2/13/07 7:58 AM, "Moritz Lennert" <mlennert at club.worldonline.be> wrote:
> >> On 13/02/07 15:29, Michael Barton wrote:
> >>> I have no idea. Perhaps I'm imagining things, but I swear that I'm seeing a
> >>> LOT more of these messages recently--with their deleterious effects on
> >>> scripting. Hamish says they've been there all along. I'm suspecting that the
> >>> code for the message has existed, but they did not get parsed for some
> >>> reason. But that is just speculation.
> >> Well in this case, there is a change by Daniel dated Jan. 28 which might
> >> be linked:
> >> - Added quotes in occurences of 'if [ -z "$var" ]'
> >> But reverting back to no quotes gives the same error message.
> >> Looking at the logic, I don't actually understand how this worked
> >> before. As I said, IIUC the x-mon test seems to be done whether you are
> >> using GIS Manager or not. But under GIS Manager there should be no x-mon...
> >> Conditonalising the check as follows:
> >> if [ "$GIS_FLAG_S"  -eq 0 ] ; then
> >>    if [ -z "$currmon" ] ; then
> >>          echo ""
> >>          echo "*** You must open a display monitor ***"
> >>          echo ""
> >>          cleanup
> >>          exit 2
> >>    fi
> >> fi
> >> makes the error message go away, but I get a new one:
> >> Usage:  /usr/lib/grass/etc/mon.select monitor_name
> >> This time, however, the map and legend are displayed correctly (without
> >> the "fix" only the legend is displayed). I can get this second error
> >> message to go away by commenting line 862:
> >> #               d.mon select=$currmon
> >> This comes from the fact that $currmon is empty in GIS Manager. Again, I
> >> don't understand why we have to deal with d.mon here if we are in the
> >> GIS Manager...and why this did not cause any problems before.
> >> Moritz
> >>> Michael
> >>> On 2/13/07 6:19 AM, "Moritz Lennert" <mlennert at club.worldonline.be> wrote:
> >>>> Michael,
> >>>> I am seeing a new error for d.vect.thematic. Trying to display a
> >>>> thematic layer fails with the message: *** You must open a display
> >>>> monitor ***
> >>>> I can reproduce this with any spearfish vector layer.
> >>>> The problem seems to be in lines 336-345 where it checks for the
> >>>> existance of an x-monitor. It seems to do this unconditionally, so even
> >>>> if you run it from the GIS Manager it still checks and fails if there is
> >>>> not monitor.
> >>>> I can't find anything recent in the commit logs that would explain this,
> >>>> so before trying to go deeper into it, I wanted to know if you had an
> >>>> idea why this is suddenly happening.
> >>>> Moritz
> >>> __________________________________________
> >>> Michael Barton, Professor of Anthropology
> >>> School of Human Evolution & Social Change
> >>> Center for Social Dynamics & Complexity
> >>> Arizona State University
> >>> phone: 480-965-6213
> >>> fax: 480-965-7671
> >>> www: http://www.public.asu.edu/~cmbarton
> > phone: 480-965-6213
> > fax: 480-965-7671
-- Daniel Calvelo Aros
