[GRASS-dev] winGRASS: debugging vector db issues
Moritz Lennert
mlennert at club.worldonline.be
Tue Feb 13 20:49:10 EST 2007
Hello Martin,
Markus tells me that you might participate in trying to debug the vector
db problems we are having in winGRASS.
Paul and I have both failed to find the reason up to now. It seems to me
that the (or at least the first...) problem is with the table description,
and within that most probably in the column description (
db__recv_*_definition in xdrtable.c and xdrcolumn.c in lib/db/dbmi_base/).
I don't know if Paul has come to the same conclusion.
For me the next steps are:
- checking whether the same happens with the other drivers (we have only
tested dbf so far)
- circonscribe the problem even further
I hope we can squish this one soon.
Moritz
