[GRASS-dev] Re: winGRASS: debugging vector db issues
Martin Landa landa.martin at gmail.com
Wed Feb 14 04:50:50 EST 2007
Hi Moritz,
I promised Markus to look at this issue. But it takes time, BTW I have
never installed GRASS under MS Windows. In any case I can try to solve
the problem. Not sure about the result;-)
Martin
2007/2/14, Moritz Lennert <mlennert at club.worldonline.be>:
> Hello Martin,
> Markus tells me that you might participate in trying to debug the vector
> db problems we are having in winGRASS.
> Paul and I have both failed to find the reason up to now. It seems to me
> that the (or at least the first...) problem is with the table description,
> and within that most probably in the column description (
> db__recv_*_definition in xdrtable.c and xdrcolumn.c in lib/db/dbmi_base/).
> I don't know if Paul has come to the same conclusion.
> For me the next steps are:
> - checking whether the same happens with the other drivers (we have only
> tested dbf so far)
> - circonscribe the problem even further
> I hope we can squish this one soon.
> Moritz
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
