[GRASS-dev] Re: winGRASS
Wed Feb 14 05:57:05 EST 2007
Moritz Lennert wrote:
> Now g.manual starts in its original form (no playing around with g.parser
> calls), but I get:
> g.manual entry=d.vect
> Starting browser <url_handler.bat> for module d.vect...
> url_handler.bat file://c:/GRASS/grass-6.3.cvs/docs/html/d.vect.html
> And then nothing happens.
Does running the command directly from a command prompt work? It's
possible that the MSys shell is interfering in some way.
