[GRASS-dev] WxPython front-end to ps.map
    Martin Landa
    landa.martin at gmail.com
    Wed Feb 14 07:41:21 EST 2007
currently ps.map should support rgbcolumn map instruction for vpoints,
vlines and vareas (committed to CVS). Testing welcomed:-)
Martin
2007/2/14, Hamish <hamish_nospam at yahoo.com>:
> > Hamish wrote:
> > > So yes, please work on it if you like to. The only thing I ask is
> > > that there is continuity with the rest of GRASS when possible. (e.g.
> > > both d.vect and ps.map use the "rgb_column" name, and work in a
> > > similar [and thus expected] way, etc)  You can probably copy a good
> > > bit of the code from d.vect.
> Martin Landa wrote:
> > Looking at the code, there is used sizecol mapping instruction. So I
> > am not sure about rgb_column. Maybe it is better to use rgbcol, but I
> > would prefer rgb_column. Or to change sizecol to size_column? Not sure
> > about that. One example in d.vect -- there is attrcol, wcolumn and
> > rgb_column -- so three different approaches.
> which is the source of my request above, to try and stop this 4-names-
> for-the-same-thing happening in future. I can only imagine how cryptic
> it all is for a non-english speaker to decode.
> Martin:
> > thinking about it I suggest to use rgbcolumn. I suppose that renaming
> > sizecol to sizecolumn is not good idea. It should wait for GRASS7.
> that's fine, my main point is that when adding new options we take
> measures to work towards greater consistency throughout the entire
> software package. It makes it much easier to learn that way.
> Preferably the development section of the wiki could have a page which
> specified style rules, like exist for source code in the SUBMITTING
> files.
> FWIW, ps.map's sizecol could be renamed sizecolumn in GRASS 6, but you
> would have to use strncmp(,7) instead of strcmp() to check the match.
> The same is true for g.*,r.*,.. module options, they can be lengthened
> without harm as the parser only checks enough letters to make sure there
> is no name collision. It's not something you want to do without a very
> good reason, but it doesn't break backwards compatibility either and so
> isn't flatly outlawed.
> Hamish
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
