[GRASS-dev] WxPython front-end to ps.map
Moritz Lennert
mlennert at club.worldonline.be
Tue Feb 20 09:29:48 EST 2007
On 14/02/07 13:41, Martin Landa wrote:
> Hi,
> currently ps.map should support rgbcolumn map instruction for vpoints,
> vlines and vareas (committed to CVS). Testing welcomed:-)
I've tested for vareas and vpoints and have not encountered any
problems. Great job !
Just one small issue:
WARNING: The mapping instruction <sizecol> will be renamed to
<sizecolumn> in future versions of GRASS. Please use <sizecol> instead.
I imagine the last sentence should read "Please use <sizecolumn>
instead, or ?
Moritz
> Martin
> 2007/2/14, Hamish <hamish_nospam at yahoo.com>:
>> > Hamish wrote:
>> > > So yes, please work on it if you like to. The only thing I ask is
>> > > that there is continuity with the rest of GRASS when possible. (e.g.
>> > > both d.vect and ps.map use the "rgb_column" name, and work in a
>> > > similar [and thus expected] way, etc) You can probably copy a good
>> > > bit of the code from d.vect.
>> Martin Landa wrote:
>> > Looking at the code, there is used sizecol mapping instruction. So I
>> > am not sure about rgb_column. Maybe it is better to use rgbcol, but I
>> > would prefer rgb_column. Or to change sizecol to size_column? Not sure
>> > about that. One example in d.vect -- there is attrcol, wcolumn and
>> > rgb_column -- so three different approaches.
>> which is the source of my request above, to try and stop this 4-names-
>> for-the-same-thing happening in future. I can only imagine how cryptic
>> it all is for a non-english speaker to decode.
>> Martin:
>> > thinking about it I suggest to use rgbcolumn. I suppose that renaming
>> > sizecol to sizecolumn is not good idea. It should wait for GRASS7.
>> that's fine, my main point is that when adding new options we take
>> measures to work towards greater consistency throughout the entire
>> software package. It makes it much easier to learn that way.
>> Preferably the development section of the wiki could have a page which
>> specified style rules, like exist for source code in the SUBMITTING
>> files.
>> FWIW, ps.map's sizecol could be renamed sizecolumn in GRASS 6, but you
>> would have to use strncmp(,7) instead of strcmp() to check the match.
>> The same is true for g.*,r.*,.. module options, they can be lengthened
>> without harm as the parser only checks enough letters to make sure there
>> is no name collision. It's not something you want to do without a very
>> good reason, but it doesn't break backwards compatibility either and so
>> isn't flatly outlawed.
>> Hamish
