[GRASS-dev] WxPython front-end to ps.map
Martin Landa
landa.martin at gmail.com
Tue Feb 20 11:06:52 EST 2007
Hi Moritz,
2007/2/20, Moritz Lennert <mlennert at club.worldonline.be>:
> I've tested for vareas and vpoints and have not encountered any
> problems. Great job !
thanks for testing!
> Just one small issue:
> WARNING: The mapping instruction <sizecol> will be renamed to
> <sizecolumn> in future versions of GRASS. Please use <sizecol> instead.
> I imagine the last sentence should read "Please use <sizecolumn>
> instead, or ?
Of course, typo fixed in CVS.
Regards,
Martin
> Moritz
> > Martin
> > 2007/2/14, Hamish <hamish_nospam at yahoo.com>:
> >> > Hamish wrote:
> >> > > So yes, please work on it if you like to. The only thing I ask is
> >> > > that there is continuity with the rest of GRASS when possible. (e.g.
> >> > > both d.vect and ps.map use the "rgb_column" name, and work in a
> >> > > similar [and thus expected] way, etc) You can probably copy a good
> >> > > bit of the code from d.vect.
> >> Martin Landa wrote:
> >> > Looking at the code, there is used sizecol mapping instruction. So I
> >> > am not sure about rgb_column. Maybe it is better to use rgbcol, but I
> >> > would prefer rgb_column. Or to change sizecol to size_column? Not sure
> >> > about that. One example in d.vect -- there is attrcol, wcolumn and
> >> > rgb_column -- so three different approaches.
> >> which is the source of my request above, to try and stop this 4-names-
> >> for-the-same-thing happening in future. I can only imagine how cryptic
> >> it all is for a non-english speaker to decode.
> >> Martin:
> >> > thinking about it I suggest to use rgbcolumn. I suppose that renaming
> >> > sizecol to sizecolumn is not good idea. It should wait for GRASS7.
> >> that's fine, my main point is that when adding new options we take
> >> measures to work towards greater consistency throughout the entire
> >> software package. It makes it much easier to learn that way.
> >> Preferably the development section of the wiki could have a page which
> >> specified style rules, like exist for source code in the SUBMITTING
> >> files.
> >> FWIW, ps.map's sizecol could be renamed sizecolumn in GRASS 6, but you
> >> would have to use strncmp(,7) instead of strcmp() to check the match.
> >> The same is true for g.*,r.*,.. module options, they can be lengthened
> >> without harm as the parser only checks enough letters to make sure there
> >> is no name collision. It's not something you want to do without a very
> >> good reason, but it doesn't break backwards compatibility either and so
> >> isn't flatly outlawed.
> >> Hamish
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
