[GRASS-dev] Re: winGRASS
Glynn Clements
glynn at gclements.plus.com
Wed Feb 14 14:20:20 EST 2007
Moritz Lennert wrote:
> Concerning the wrong setting for GISRC, this seems to come from the
> following line in etc/Init.bat:
> set WINGISRC=%HOME%\.grassrc6
> 'echo %HOME%' just results in %HOME%. Is HOME a valid Win env variable
No, in the sense that Windows doesn't set it by default. HOME should
probably be set to %USERPROFILE% if it isn't already set.
> (and what would $HOME actually be in a windows environment) ?
%USERPROFILE% will typically be C:\Documents and Settings\<username>
(subject to localisation of directory names).
