[GRASS-dev] Re: winGRASS
Moritz Lennert mlennert at club.worldonline.be
Tue Feb 20 03:58:17 EST 2007
On Wed, February 14, 2007 20:20, Glynn Clements wrote:
> Moritz Lennert wrote:
>> Concerning the wrong setting for GISRC, this seems to come from the
>> following line in etc/Init.bat:
>> set WINGISRC=%HOME%\.grassrc6
>> 'echo %HOME%' just results in %HOME%. Is HOME a valid Win env variable
> No, in the sense that Windows doesn't set it by default. HOME should
> probably be set to %USERPROFILE% if it isn't already set.
Yes, this works.
Paul, do you want me to integrate such things directly in CVS, or do you
prefer doing it yourself ?
Moritz
