[GRASS-dev] Modules (was: Cygwin winGRASS 6.2 Errors! [SUCESS})
Thu Feb 15 19:57:20 EST 2007
Michael Barton wrote:
> There is Inkscape, which does SVG. But the problem with this and CAD
> packages is that they aren't automatically georeferenced. And doing this
> post hoc can lead to problems occasionally. But it IS a lot easier to work
> with.
Would it help if there was some way to pre-generate a "template" file?
E.g. if you started with a file containing an existing map (or even
just a grid) using geographic coordinates, would you then be able to
easily add data using the same coordinate system?
