[GRASS-dev] Modules (was: Cygwin winGRASS 6.2 Errors!
[SUCESS})
Michael Barton
michael.barton at asu.edu
Fri Feb 16 01:14:36 EST 2007
I haven't used Inscape enough to know if this is workable or not. Nice idea.
Michael
On 2/15/07 5:57 PM, "Glynn Clements" <glynn at gclements.plus.com> wrote:
> Michael Barton wrote:
>> There is Inkscape, which does SVG. But the problem with this and CAD
>> packages is that they aren't automatically georeferenced. And doing this
>> post hoc can lead to problems occasionally. But it IS a lot easier to work
>> with.
> Would it help if there was some way to pre-generate a "template" file?
> E.g. if you started with a file containing an existing map (or even
> just a grid) using geographic coordinates, would you then be able to
> easily add data using the same coordinate system?
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
