[GRASS-dev] Re: Fix Help button in gis.m raster/vector display conf locks up gis.m
Michael Barton michael.barton at asu.edu
Fri Feb 16 12:35:17 EST 2007
Maris,
I was still waiting on wingrass to decide how best to deal with g.manual
running modally on some systems (i.e., on your Linux system but not on Mac
OS X).
On my Mac, spawn works but generates an annoying and useless message to
console each time. It doesn't matter if I add the --q switch or not.
Oddly, in your case it only generates the message if you DO use the --q
switch. This makes me wonder what the --q switch is doing in g.manual since
it appears to be creating verbose output rather than preventing it.
If I declare the global variable devnulls at the beginning of the options
panel procedure, I can use the form
spawn g.manual module > $devnulls &
OR
exec g.manual module > $devnulls &
Both work fine on my Mac and do NOT generate the annoying message.
How do these work on your system?
Moritz -- Does this work with Windows???
Michael
On 2/16/07 10:02 AM, "Maris Nartiss" <maris.gis at gmail.com> wrote:
> Hi,
> probablhy You did not changed anything, but I was ahcking around and
> forgot about it.
> Newest results (GRASS 6.3 a week(?) old CVS (I have not updated for some
> time)):
> Plain version (no modification):
> * gis.m raster help button locks up gis.m. Have to xkill it;
> * gis.m Help-> GRASS Help works fine - no lockups etc.
> * comandline g.manual - comandline remains locked till I exit help browser.
> run g.manual --q d.rast:
> * gis.m raster help locks up gis.m till I close my help browser. After
> closing it, gis.m is useable
> spawn g.manual --q d.rast:
> * after launching Help browser, I can use gis.m w/o problems without
> requirement to close help (yapiiiii).
> spawn g.manual d.rast:
> * Same as without --q (works), except now is a message printed to
> console about launching browser.
> IMHO best is "spawn g.manual --q module", as it prints no message and
> allows to use gis.m in paralel to help page browsing.
> Should I create new patch for this?
> WBR,
> Maris.
> 2007/2/14, Michael Barton <michael.barton at asu.edu>:
>> Maris,
>> I haven't changed anything, so it will work the same.
>> Since it doesn't lock up on my Mac, it is hard to test alternative
>> approaches. Maybe you can help.
>> Instead of run, try spawn and the g.manual --quiet
>> Also, try the execute statement used in the menu version of help.
>> Which of these work better, worse, same?
>> I'd also like to find a solution that also works in Windows. Currently, it
>> doesn't work at all or crashes in winGRASS.
>> Michael
>> On 2/13/07 1:43 AM, "Maris Nartiss" <maris.gis at gmail.com> wrote:
>>> Hi all,
>>> I tested recent g.manual with gis.m.
>>> Starting help now launches my browser (Konqueror) and locks up gis.m.
>>> After I close browser, gis.m is unlocked - usable. Now works like in
>>> 6.2 time. Still IMHO this sucks.
>>> As I understood, we may not be able to change way g.manual works as it
>>> will break backward compatability (probably new switch -spawn could do
>>> trick?). If nothing more can be done for g.manual, then we should
>>> atleast make gis.m usable by changing all "run g.manual" calls to
>>> "spawn g.manual".
>>> Just my 0.02c,
>>> Maris.
>>> 2007/2/12, Michael Barton <c.michael.barton at gmail.com>:
>>>> g.manual --quiet is a good solution. Thanks.
>>>> Michael
>>>> On Feb 11, 2007, at 11:03 PM, Hamish wrote:
>> __________________________________________
>> Michael Barton, Professor of Anthropology
>> School of Human Evolution & Social Change
>> Center for Social Dynamics & Complexity
>> Arizona State University
>> phone: 480-965-6213
>> fax: 480-965-7671
>> www: http://www.public.asu.edu/~cmbarton
Center for Social Dynamics and Complexity
phone: 480-965-6213
fax: 480-965-7671
