[GRASS-dev] Re: Fix Help button in gis.m raster/vector display conf
locks up gis.m
Maris Nartiss
maris.gis at gmail.com
Fri Feb 16 13:39:23 EST 2007
Hi Michael,
I'm really sorry for my english. Reading Linux realted RTFMs may not
be best way how to learn language.
I was saying, that --q gives NO output to console, without --q it
print that unneccessary message about "Starting browser...".
"exec g.manual d.rast > /dev/null &" will print same message "Starting
browser <konqueror> for module d.rast" to console. Where is $devnulls
defined? By simply adding "global devnulls" I had no success, thus I
used plain /dev/null for testing.
"spawn g.manual d.rast > /dev/null &" fails completly with error
message in console - "Sorry, <&> is not a valid parameter" (translated
from Latvian).
I wote for using "spawn g.manual --q module" as it gives best results.
Maris.
PS. Michael, have You updated Your g.manual module after 12. feb.
2007? I see, that --q support was introduced after 12 feb.
2007/2/16, Michael Barton <michael.barton at asu.edu>:
> Maris,
> I was still waiting on wingrass to decide how best to deal with g.manual
> running modally on some systems (i.e., on your Linux system but not on Mac
> OS X).
> On my Mac, spawn works but generates an annoying and useless message to
> console each time. It doesn't matter if I add the --q switch or not.
> Oddly, in your case it only generates the message if you DO use the --q
> switch. This makes me wonder what the --q switch is doing in g.manual since
> it appears to be creating verbose output rather than preventing it.
> If I declare the global variable devnulls at the beginning of the options
> panel procedure, I can use the form
> spawn g.manual module > $devnulls &
> OR
> exec g.manual module > $devnulls &
> Both work fine on my Mac and do NOT generate the annoying message.
> How do these work on your system?
> Moritz -- Does this work with Windows???
> Michael
> On 2/16/07 10:02 AM, "Maris Nartiss" <maris.gis at gmail.com> wrote:
> > Hi,
> > probablhy You did not changed anything, but I was ahcking around and
> > forgot about it.
> > Newest results (GRASS 6.3 a week(?) old CVS (I have not updated for some
> > time)):
> > Plain version (no modification):
> > * gis.m raster help button locks up gis.m. Have to xkill it;
> > * gis.m Help-> GRASS Help works fine - no lockups etc.
> > * comandline g.manual - comandline remains locked till I exit help
> browser.
> > run g.manual --q d.rast:
> > * gis.m raster help locks up gis.m till I close my help browser. After
> > closing it, gis.m is useable
> > spawn g.manual --q d.rast:
> > * after launching Help browser, I can use gis.m w/o problems without
> > requirement to close help (yapiiiii).
> > spawn g.manual d.rast:
> > * Same as without --q (works), except now is a message printed to
> > console about launching browser.
> > IMHO best is "spawn g.manual --q module", as it prints no message and
> > allows to use gis.m in paralel to help page browsing.
> > Should I create new patch for this?
> > WBR,
> > Maris.
> > 2007/2/14, Michael Barton <michael.barton at asu.edu>:
> >> Maris,
> >> I haven't changed anything, so it will work the same.
> >> Since it doesn't lock up on my Mac, it is hard to test alternative
> >> approaches. Maybe you can help.
> >> Instead of run, try spawn and the g.manual --quiet
> >> Also, try the execute statement used in the menu version of help.
> >> Which of these work better, worse, same?
> >> I'd also like to find a solution that also works in Windows. Currently,
> it
> >> doesn't work at all or crashes in winGRASS.
> >> Michael
> >> On 2/13/07 1:43 AM, "Maris Nartiss" <maris.gis at gmail.com> wrote:
> >>> Hi all,
> >>> I tested recent g.manual with gis.m.
> >>> Starting help now launches my browser (Konqueror) and locks up gis.m.
> >>> After I close browser, gis.m is unlocked - usable. Now works like in
> >>> 6.2 time. Still IMHO this sucks.
> >>> As I understood, we may not be able to change way g.manual works as it
> >>> will break backward compatability (probably new switch -spawn could do
> >>> trick?). If nothing more can be done for g.manual, then we should
> >>> atleast make gis.m usable by changing all "run g.manual" calls to
> >>> "spawn g.manual".
> >>> Just my 0.02c,
> >>> Maris.
> >>> 2007/2/12, Michael Barton <c.michael.barton at gmail.com>:
> >>>> g.manual --quiet is a good solution. Thanks.
> >>>> Michael
> >>>> On Feb 11, 2007, at 11:03 PM, Hamish wrote:
> >> __________________________________________
> >> Michael Barton, Professor of Anthropology
> >> School of Human Evolution & Social Change
> >> Center for Social Dynamics & Complexity
> >> Arizona State University
> >> phone: 480-965-6213
> >> fax: 480-965-7671
> >> www: http://www.public.asu.edu/~cmbarton
> Center for Social Dynamics and Complexity
> phone: 480-965-6213
> fax: 480-965-7671
