[GRASS-dev] [grass-code I][297] cannot add layer with double click
grass-codei at wald.intevation.org
Sat Feb 17 09:26:21 EST 2007
code I item #297, was opened at 2007-02-17 15:26
Status: Open
Priority: 3
Submitted By: Maciej Sieczka (msieczka)
Assigned to: Nobody (None)
Summary: cannot add layer with double click
Issue type: module bug
Issue status: None
GRASS version: CVS HEAD
GRASS component: gis.m
Operating system: all
Operating system version:
GRASS CVS checkout date, if applies (YYMMDD): 070217
Initial Comment:
Trying to add a raster or vector to gis.m's when adding it to layers list selecting it with mouse double click results in an error:
Invalid command name "streams at sieczka"
invalid command name "streams at sieczka"
while executing
"$tree parent $node"
(procedure "GSelect_::select" line 4)
invoked from within
"GSelect_::select $tree $node $id "
(procedure "GSelect_::selectclose" line 4)
invoked from within
"GSelect_::selectclose 3 .selwinmainframeframepw1f1frameswsfframefrnameb.sw.tree [string range [lindex [.selwinmainframeframepw1f1frameswsfframefrnameb..."
(command bound to event)
However, highlighting the layer and clicking OK works. Only double click doesn't.
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=297&group_id=21
