[GRASS-dev] [bug #5219] (grass) d.vect display=cat works only
for layer 1
Maciej Sieczka
tutey at o2.pl
Sat Feb 17 16:04:26 EST 2007
Hi!
Browsing old emails I found this one I never replied to. Sorry. Please
read below.
Hamish wrote:
> Martin Landa wrote:
>>> this bug's URL: http://intevation.de/rt/webrt?serial_num=5219
>> It seems you have to specify the llayer parameter too, e.g.
>> d.erase;d.vect pts2 layer=2 display=shape,cat llayer=2
>> It is really confusing, I am not sure how to solve it. Do you think,
>> would be enough to print a given warning, e.g. "The layer number (2)
>> and layer number for labels (1) are not the same.".
> It would appear to be perfectly legal to display shapes from one layer
> and labels from another.
Hamish is correct. However, it seems to me that when the user runs:
he will expect that categories for layer 2 will be displayed, not for
layer 1, as it happens currently. Only if he really wants to display
geometry from layer 2 and categories (or other labels) belonging to
layer 1, he should have to explicitely set llayer=1.
The conclussion is, if my thinking is correct: shouldn't llayer default
to layer, if not explicitely requested differently?
If this was implemented, the warning which Matin proposed in his patch
would be redundant.
Cheers
Maciek
