[GRASS-dev] [bug #5499] (grass) bash scripts starting with
#!/bin/sh
Glynn Clements
glynn at gclements.plus.com
Mon Feb 19 11:41:47 EST 2007
Hamish wrote:
> (my regex sucks, what does the "\\s*" part of "\\s*:\\s*" match?)
My guess would be that it's supposed to match any "whitespace"
character, but that's non-standard (it works in GNU sed 4.1.5, but
doesn't appear to be documented in the sed Info file). More portable
solutions include:
1. Just use a space.
2. Use a set containing a space or a tab, i.e. [ <tab>] where <tab> is
a literal tab character.
3. Use [:space:] or [:blank:]. The latter matches space or tab, while
the former matches a locale-dependent set; in the C/POSIX locale, it
matches space, tab, newline, carriage-return, form-feed and
vertical-tab.
