[GRASS-dev] New v.digit
Paul Kelly
paul-grass at stjohnspoint.co.uk
Sun Feb 25 10:38:51 EST 2007
On Sun, 25 Feb 2007, Michael Barton wrote:
> I added the OK button. It's in the cvs now.
Hello Michael
I just tested this and as far as I can see it doesn't work correctly. You
stil have to press enter in the box after changing the line width for it
to be picked up. And the default line width still isn't placed in the box
to start with. Also if there is an OK button there should be a cancel too
I think.
Paul
> Michael
> On 2/24/07 12:19 PM, "Glynn Clements" <glynn at gclements.plus.com> wrote:
>> Markus Neteler wrote:
>>>>> PPS: A wish: having "close" buttons in all "Settings" tabs would
>>>>> be great
>>>> Close buttons in *tabs*? For what purpose?
>>> Right, I meant a close button for the entire window
>>> or something reasonable.
>>> Take for example the "Background" tab:
>>> - click "Add command"
>>> - write "Winnie The Pooh"
>>> - then? Kill the entire settings window - not really obvious
>>> ("Winnie The Pooh" is then silently ignored/disappears)
>>> I would expect some "confirm" thing or so or a "Done"
>>> button below all tabs.
>> Ah, an "Ok" button (apply changes and close window).
>> Add it to the RT as a wish; for now, I would rather stick to fixing
>> anything which broke as a result of switching from libraster to Tk.
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
