[GRASS-dev] New v.digit
Glynn Clements
glynn at gclements.plus.com
Sun Feb 25 20:18:34 EST 2007
Michael Barton wrote:
> I've improved the performance of the OK button. But what I really did was
> A couple of bugs I noted:
> 2. Whenever I try to do something with the display cats window (add new), it
> crashes v.digit. I apparently don't understand how it's supposed to work.
> But it shouldn't crash it either.
This one is due to the restructuring changes (prior to actually using
Tk instead of libraster). The "display cats" tool doesn't update the
global variable last_cat_line, which the "Add new" button uses (along
with the Delete button which appears alongside the new category).
Fixed in CVS.
