[GRASS-dev] Re: g.rename consolidation
Maris Nartiss
maris.gis at gmail.com
Mon Feb 26 04:23:17 EST 2007
Just a small flamme notice.
I had opportunity to watch how total n00bs and lam3s work with GRASS.
One of problems for them was how to know whem some module has finished
it's work witout error. Curretnly lot of GRASS modules output
different progress info, that many users may found fustrating, but
after reporting about "opening" and "closing" maps, it does not report
"success" at end. In good old times it was easy to know, that module
has finished it's run - it was just returning GRASS prompt to user to
get new command. Nowdays progress may go to different window somewhere
behind other windows between gazzilion of other unnecessary info and
it may be hard to distinguish what's important and what is not and as
progress bar due extensive output may be scrolled up far, far away,
how to know how many % module has completed?
Just my 0.02 $
Maris.
2007/2/26, Jáchym Čepický <jachym.cepicky at gmail.com>:
> Hi,
> 2007/2/26, Martin Landa <landa.martin at gmail.com>:
> > Hi Hamish,
> > I think it is better to use G_message() (or more advanced G_ fn) for
> > *all* module messages. fprintf (stdout, ) should be used for the
> > *output* not for the messages. It mixed two different things together
> > which would be better to separate. I think that mixing messages and
> > module output would cause problems in the future. All message should
> > be controlled by GRASS_VERBOSE level or GRASS_MESSAGE_FORMAT.
> IMHO it makes sence to introduce more sophisticated functions fo
> G_message_*. But to parse messages in any GUI or other interface woul
> d be really complicated, if GRASS_MESSAGE_FORMAT would not influence
> it.
> In my opinion, GRASS modules are verbosed too much (e.g. see
> r.terraflow). Message has for the user only then sence, if it is
> error, warning or user will have to wait longer time (so G_percent
> should be used imidietly after this). otherwise it is task for G_debug
> So basicly, I would like to remove most of the "closing maps" and
> similar messages. if you want to inform the user about e.g. how many
> points were processed, we should use fprintf to stdout for it, since
> this is not a message, but a result...
> just my 2 cents
> jachym
> Jachym Cepicky
> e-mail: jachym.cepicky gmail com
> URL: http://les-ejk.cz
> GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
