[GRASS-dev] DBMI parse error question
Markus Neteler neteler at itc.it
Tue Feb 27 18:34:07 EST 2007
Hi Kirk,
I renamed the column to "datum" and still it fails.
Markus
On Tue, Feb 27, 2007 at 05:12:00PM -0600, Kirk Wythers wrote:
> Hi Markus,
> I had a similar error once when I used 'data' as a field name.
> Kirk
> On Feb 27, 2007, at 4:38 PM, Markus Neteler wrote:
> >Hi,
> >I try to import a map from PostgreSQL into GRASS/DBF driver
> >with v.in.db, but get
> >DBMI-DBF driver error:
> >SQL parser error in statement:
> >create table ticks_feltre_2002_2006_sites ( ID integer, comune
> >varchar(250), localita varchar(250), microsito varchar(250), data
> >date, ora time, larve integer, ninfe integer, adm integer, adf
> >integer, adtot integer, tcelsius double precision, umidrel double
> >precision, note varchar(250), mapsheet varchar(250), mgrs varchar
> >(250), stazione varchar(250), periodo_prelievo varchar(250), north
> >double precision, east double precision, siteid integer )
> >Cannot create table
> >but I don't see where the evil is:
> >echo " ID integer, comune varchar(250), localita varchar(250),
> >microsito varchar(250), data date, ora time, larve integer, ninfe
> >integer, adm integer, adf integer, adtot integer, tcelsius double
> >precision, umidrel double precision, note varchar(250), mapsheet
> >varchar(250), mgrs varchar(250), stazione varchar(250),
> >periodo_prelievo varchar(250), north double precision, east double
> >precision, siteid integer" | tr -s ',' '\n' | sort
> > adf integer
> > adm integer
> > adtot integer
> > comune varchar(250)
> > data date
> > ID integer
> > larve integer
> > mgrs varchar(250)
> > ninfe integer
> > note varchar(250)
> > ora time
> > siteid integer
> >Any ideas? Of course it would be fancy to have a more reasonable
> >error message. This error uses to pop up if preserved words are used
> >as column names, but I don't see any (even, it should tell me in an
> >ideal world).
> >Markus
> >_______________________________________________
> >grass-dev mailing list
> >grass-dev at grass.itc.it
> >http://grass.itc.it/mailman/listinfo/grass-dev
