[GRASS-dev] DBMI parse error question
Hamish
hamish_nospam at yahoo.com
Tue Feb 27 20:01:29 EST 2007
Markus Neteler wrote:
> > >I try to import a map from PostgreSQL into GRASS/DBF driver
> > >with v.in.db, but get
> > >DBMI-DBF driver error:
> > >SQL parser error in statement:
> > >create table ticks_feltre_2002_2006_sites ( ID integer, comune
> > >varchar(250), localita varchar(250), microsito varchar(250), data
> > >date, ora time, larve integer, ninfe integer, adm integer, adf
> > >integer, adtot integer, tcelsius double precision, umidrel double
> > >precision, note varchar(250), mapsheet varchar(250), mgrs varchar
> > >(250), stazione varchar(250), periodo_prelievo varchar(250), north
> > >double precision, east double precision, siteid integer )
> > >Cannot create table
> > >but I don't see where the evil is:
> > >echo " ID integer, comune varchar(250), localita varchar(250),
> > >microsito varchar(250), data date, ora time, larve integer, ninfe
> > >integer, adm integer, adf integer, adtot integer, tcelsius double
> > >precision, umidrel double precision, note varchar(250), mapsheet
> > >varchar(250), mgrs varchar(250), stazione varchar(250),
> > >periodo_prelievo varchar(250), north double precision, east double
> > >precision, siteid integer" | tr -s ',' '\n' | sort
> > > adf integer
> > > adm integer
> > > adtot integer
> > > comune varchar(250)
> > > data date
> > > ID integer
> > > larve integer
> > > mgrs varchar(250)
> > > ninfe integer
> > > note varchar(250)
> > > ora time
> > > siteid integer
> > >Any ideas? Of course it would be fancy to have a more reasonable
> > >error message. This error uses to pop up if preserved words are
> > >used as column names, but I don't see any (even, it should tell me
> > >in an ideal world).
cutting the list in half, trialing that, cutting in half again, etc.
shows that "ora time" is the offending entry.
Hamish
