[GRASS-dev] gdal-grass plugin fails during ./configure with GRASS
6.3 CVS
Maciej Sieczka
tutey at o2.pl
Mon Jan 1 12:28:34 EST 2007
With current GRASS 6.3 CVS gdal-grass 1.3.1.2 and 1.3.2 fail during
configure:
$ ./configure --with-grass=/usr/local/grass-6.3.cvs/
checking for gdal-config... /usr/local/bin/gdal-config
using /usr/local/lib/gdalplugins as GDAL shared library autoload directory
checking for G_asprintf in -lgrass_gis... no
configure: error: --with-grass=/usr/local/grass-6.3.cvs/ requested, but
libraries not found! Perhaps you need to set LD_LIBRARY_PATH to
include /usr/local/grass-6.3.cvs//lib?
GRASS is installed /usr/local/grass-6.3.cvs/, the
/usr/local/grass-6.3.cvs/lib is present in the /etc/ld.so.conf and I
remembered to run ldconfig.
Did something change in GRASS between 6.2 and 6.3, or in GDAL, that
gdal-grass plugin won't build with GRASS 6.3? Both gdal-grass versions
configure fine with GRASS 6.2.2 (CVS 23.12.2006).
Using GDAL 1.4 CVS 25.12.2006.
Any hints appreciated!
Thanks.
Maciek
