[GRASS-dev] g.region print flags combination
Maciej Sieczka
tutey at o2.pl
Mon Jan 1 12:51:49 EST 2007
Hi Martin!
Thanks for cleaning up g.region. Unfortunately, it seems that in the
process you have accidently removed a feature - it is now impossible to
use "g.region -g" alone anymore - one has to call it in combination
with other flags now.
Although your approach is good, currently it breaks some GRASS scripts
using "g.region -g", eg. d.out.gpsdrive, r.plane, r.shaded.relief,
r.tileset and unknown number of user scripts. I suggest to revert this
change and leave it for GRASS 7.
Regards and thanks.
Maciek
