[GRASS-dev] g.region print flags combination
    Martin Landa
    landa.martin at gmail.com
    Mon Jan  1 13:13:12 EST 2007
Hi Maciek,
sorry, you are right. I will fix it as soon as possible.
Regards, Martin
2007/1/1, Maciej Sieczka <tutey at o2.pl>:
> Hi Martin!
> Thanks for cleaning up g.region. Unfortunately, it seems that in the
> process you have accidently removed a feature - it is now impossible to
> use "g.region -g" alone anymore - one has to call it in combination
> with other flags now.
> Although your approach is good, currently it breaks some GRASS scripts
> using "g.region -g", eg. d.out.gpsdrive, r.plane, r.shaded.relief,
> r.tileset and unknown number of user scripts. I suggest to revert this
> change and leave it for GRASS 7.
> Regards and thanks.
> Maciek
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
