[GRASS-dev] g.region print flags combination
Martin Landa
landa.martin at gmail.com
Tue Jan 2 06:15:13 EST 2007
I hope, now it is fixed in CVS.
Martin
2007/1/1, Martin Landa <landa.martin at gmail.com>:
> Hi Maciek,
> sorry, you are right. I will fix it as soon as possible.
> Regards, Martin
> 2007/1/1, Maciej Sieczka <tutey at o2.pl>:
> > Hi Martin!
> > Thanks for cleaning up g.region. Unfortunately, it seems that in the
> > process you have accidently removed a feature - it is now impossible to
> > use "g.region -g" alone anymore - one has to call it in combination
> > with other flags now.
> > Although your approach is good, currently it breaks some GRASS scripts
> > using "g.region -g", eg. d.out.gpsdrive, r.plane, r.shaded.relief,
> > r.tileset and unknown number of user scripts. I suggest to revert this
> > change and leave it for GRASS 7.
> > Regards and thanks.
> > Maciek
> Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
